Nu erbjuder vi hela 25% i rabatt på Mishimoto!
100-talet racingkylare / kylare i lager för omgående leverans.
Används flitigt inom racing, rally och drifting.
Mishimoto erbjuder sin unika utbytesgaranti.
Används av bl.a:
CHRIS FORSBERG - Formula D PRO Championship Winner 2009 - Nissan 350z (Team NOS, USA)
MATT WALDIN - Nissan 350z (Formula Drift, D1GP, USA)
AMS PERFORMANCE - TIME ATTACK MITSUBISHI EVO X (USA)
Och många, många fler...se http://www.mishimoto.com/mishimoto-race.html samt http://www.mishimoto.com/mishimoto-rides.html för ett urval utav referenser.
Mishimoto Racing Radiator
Whether you're a daily driver searching for a dependable quality upgrade from your current OEM radiator, or you're a devoted racer who needs a lightweight, high-performance radiator, Mishimoto has just what you're looking for.
Many drivers overlook the importance of having a high-quality aluminum radiator installed, yet it is one of the most important components in your vehicle's engine.
Mishimoto performance radiators are designed to efficiently reduce the heat from vital areas.
Made with 100% brazed aluminum for a clean OEM fit, our performance aluminum radiators ensure excellence and a lifetime of efficient cooling.
Perfect for any turbocharged, supercharged, or nitrous-oxide engine.
Bilmodeller / Årsmodeller
TOYOTA Celica 00~05
TOYOTA Corolla 83~87
TOYOTA Corolla 03~07
TOYOTA MR2 90~97
TOYOTA Supra 86~92
TOYOTA Supra 93~98
TOYOTA Tundra 00~04
PRIS: endast 2996kr/st inkl moms!
Mishimoto Racing Thermostat
Mishimoto Mitsubishi racing thermostats will promote greater cooling efficiency throughout your engine.
The Mishimoto racing thermostat will significantly lower high engine temperature produced by modified and upgraded turbo applications.
Once the engine is fully warmed up the Mishimoto racing thermostat will open up at a lower temperature than standard thermostats, also allowing the coolant to flow through the engine sooner thus reducing and maintaining cooler engine temperatures.
Bilmodeller / Årsmodeller:
TOYOTA Celica 02~05
TOYOTA Corolla 02~05
TOYOTA MR2 02~05
TOYOTA Supra 93~98
PRIS: endast 746kr/st inkl moms!
OBS!
Erbjudandet gäller hela sortimentet, inte enbart till Toyota.
Erbjudandet gäller till och med 31/3 2010.
Kampanjen gäller enbart dessa produkter och kan ej kombineras med andra kampanjer/erbjudanden/rabatter.
Skulle din modell vara slutsåld så tar vi givetvis hem en till dig till samma pris.
Ange kod "TCS25" i anvisat fält vid beställning för att erhålla kampanjpriset/rabatten.
För att beställa - http://WWW.RAIDOPOWER.SE
