MR2 Turbo - Looking for Original avgassystem!
Postat: tor 04 jun 2015, 23:52:03
av simba83
Hej TCS!
I just became a member here. I recently imported a JDM MR2 Turbo from Japan - GT with full specs and have run into a few problems at reg.besiktning here. I am wondering if you or anyone you know might have an original avgassystemet from an MR2 Turbo. I can buy it or if someone is kind enough... I can borrow or rent it to clear the inspection process.
Look forward to hearing from all you cool folks!
Thanks and cheers!
Ethan E.
Re: MR2 Turbo - Looking for Original avgassystem!
Postat: tis 16 jun 2015, 17:23:20
av todie
Hey there. Do u still have the cat mounted?
I have a exhaust from cat and back.
Postat: tis 16 jun 2015, 17:36:25
av simba83
Hi!
Yes I have the cat. I basically need the end silencer with 2 exhaust output ports - original. Just a very stupid demand from the inspection i think! One of the very many actually...
Can you possibly send me some photos?
Many thanks and regards!
Ethan Emmanuel
Postat: tis 16 jun 2015, 19:58:57
av todie
Sounds really weird if they demand that you have to have two outputs. I have the exhaust wich i had on my turbo when i registered it. but its only single output from cat and back with silencer etc. it should work. Im not home right now... im gerting home tomorrow night...so i try to fix a picture on thursday.
Postat: tis 16 jun 2015, 22:20:13
I think they just want the original exhaust, and that happens to have two outputs(?).
I know other people that also failed the registration because the exhaust system was not the original one.
..But usally they do not care baout it as long as it doesn't sound too much.
Postat: tis 16 jun 2015, 22:36:51
av simba83
Exactly that is the whole story behind this dilemna...
So do you have anything to offer in this regard...?
