MR2 Turbo - Looking for Original avgassystem!
simba83
Bilmodell: MR2 Turbo JDM
Årsmodell: 1992
PostOrt: Sollentuna
Inlägg av simba83 »
Hej TCS!
I just became a member here. I recently imported a JDM MR2 Turbo from Japan - GT with full specs and have run into a few problems at reg.besiktning here. I am wondering if you or anyone you know might have an original avgassystemet from an MR2 Turbo. I can buy it or if someone is kind enough... I can borrow or rent it to clear the inspection process.
Look forward to hearing from all you cool folks!
Thanks and cheers!
Ethan E. :)
todie
Bilmodell: Toyota MR2 Turbo
Årsmodell: 1993
PostOrt: Vänersborg
OrgNr: 821105-5515
Re: MR2 Turbo - Looking for Original avgassystem!
Inlägg av todie »
Hey there. Do u still have the cat mounted?
I have a exhaust from cat and back.
simba83
Årsmodell: 1992
PostOrt: Sollentuna
Inlägg av simba83 »
Hi!
Yes I have the cat. I basically need the end silencer with 2 exhaust output ports - original. Just a very stupid demand from the inspection i think! One of the very many actually... :)
Can you possibly send me some photos?
Many thanks and regards!
Ethan Emmanuel
todie
Årsmodell: 1993
PostOrt: Vänersborg
OrgNr: 821105-5515
Inlägg av todie »
Sounds really weird if they demand that you have to have two outputs. I have the exhaust wich i had on my turbo when i registered it. but its only single output from cat and back with silencer etc. it should work. Im not home right now... im gerting home tomorrow night...so i try to fix a picture on thursday.
I think they just want the original exhaust, and that happens to have two outputs(?).
I know other people that also failed the registration because the exhaust system was not the original one.
..But usally they do not care baout it as long as it doesn't sound too much.
simba83
Årsmodell: 1992
PostOrt: Sollentuna
Inlägg av simba83 »
Exactly that is the whole story behind this dilemna... :)
So do you have anything to offer in this regard...?
