S: MSD DIS4 PLUS med 4st MSD tändspolar
Postat: sön 10 maj 2009, 21:28:50
av Hansen
säljer mitt MSD DIS4 PLUS med 4st MSD tändspolar
Four cylinder distributorless ignition applications (with two coil packs) will benefit from the incredible spark energy of the the new MSD Programmable DIS-2 Ignition Control as well as its ignition programming capabilities! MSD"s CD circuits work with state-of-the-art IGBT coil drivers to deliver a spark with 190 mj of spark energy! Below 3,300 rpm, there is series of multiple sparks that burns in the cylinder for 20 producing a smooth idle with great throttle response. You get to control all of this spark energy through an incredible array of timing and rpm programs. The heart of the Programmable DIS-2 is a 15Mh microprocessor that reviews, analyzes and manages every trigger signal and is capable of up to 15 million instructions per second! The end result is a powerful ignition control with endless programming capabilities to produce reliable performance.
Individual Cylinder Timing: Maximize the performance of each cylinder to compensate for differing dynamics in airflow and other variances. The spark to each cylinder can be adjusted up to 5 in 0.1 increments which will eliminate any compromises in timing while developing the full potential of the engine.
Launch Timing Curve: Program a separate timing curve exclusively for the launch! This is a big help in compensating for varying track conditions to maximize traction.
Boost Timing Curve: For turbo or superchargered applications an optional MAP sensor can be installed so you can control the ignition timing in relation to boost pressure. The timing can be programmed from 0 - 25 in conjunction to for boost pressure ranging from 0 - 45 psi in 0.50 psi increments.
Multi-Step Retard: Three separate stages of retard can be activated by either rpm or a separate activation wire. This is perfect for all nitrous applications. Programmable from 0 -15 in 0.1 degree increments within 800 - 15,000 rpm in 100 rpm steps.
Gear RPM and Retards: Program a different rpm shift point for each gear as well as a retard for every gear change.
Three Rev Limits: Set three different rev limits for the burnout, the holeshot and top end overrev protection in 100 rpm increments.
Spark Energy: 190 millijoules Per Spark
Primary Voltage: 500 Volts
Output Voltage - 50,000 w/ Blaster Coils
Spark Duration: 20
Operating Voltage: 11-18
Volts, Negative Ground
Current Draw: 8 Amps @ 10,000 RPM
RPM Range: 15,000 RPM with 14 Volt Input
PRIS för allt 4000:-
Re: S: MSD DIS4 PLUS med 4st MSD tändspolar
Postat: mån 18 maj 2009, 12:27:54
av Hansen
upp
Postat: mån 25 maj 2009, 21:47:18
av Hansen
nytt pris 3500:-
ring eller skriv om ni är intreserad ;)
070-2061379
Postat: fre 29 maj 2009, 07:43:17
av Hansen
va inte blyg nu, kom å köp. Behöver pengar nu till mappningen :D
Postat: mån 01 jun 2009, 21:20:00
av Hansen
nytt pris 3000:-
Postat: tis 09 jun 2009, 19:18:51
av Hansen
upp
Postat: tis 09 jun 2009, 22:04:07
av Jonex
Jag fundrar på det.. men jag är inte säker på om/när jag får användning för det..
Postat: tis 09 jun 2009, 22:08:52
av Hansen
Du kan göra som jag gör, köp först å tänk sen :D
Jonex skrev:Jag fundrar på det.. men jag är inte säker på om/när jag får användning för det..
